Engine compartment is painted and the final assembly of the steering is done.
I just need a new pressure plate for the clutch and some lower control arm bushings.
Engine compartment painted and ready for v6
- v6spider
http://www.v6spider.com
- v6spider
Re: Engine compartment painted and ready for v6
A 300+ hp naturally aspirated 4.3L Chevy vortec!WYSpider wrote:What v6 are you dropping in?
Cheers!
Rob
all these big motor conversions make me nervous because you cut away the upper transverse bracing on the firewall. It seems to me it would be worthwhile to install a removable brace across that gap. It would help if your motor is aluminum.
- v6spider
That is the plan actually. but first I have get everything in there and see what room I have left.azruss wrote:all these big motor conversions make me nervous because you cut away the upper transverse bracing on the firewall. It seems to me it would be worthwhile to install a removable brace across that gap. It would help if your motor is aluminum.
Btw the engine is only 75 lbs heavier than the twin cam.
the only issues I had in the first car I built were caused by extreme rust damage weakening the structure of the car.
Cheers
Rob
