The Engine, Trans, and Driveline are now installed after moving the engine mounts ahead 3/8" and centering the transmission mount. Now I am working on fabricating radiator mounts and hooking up hoses and wiring.
Cheers!
Rob
V6, Transmission & Driveline Installed!
- v6spider
http://www.v6spider.com
- 81SPIDERMATT
Re: V6, Transmission & Driveline Installed!
sweet ... congrats
- v6spider
Thanks! I'm chomping at the bit. The summer is going away quick! It's not long now though.81SPIDERMATT wrote:sweet ... congrats
Rob
Hi Rob,
Looking very good!
What did you end up using for a rear end?
Jordan
Looking very good!
Jordan
- v6spider
Hi Jordan,burgandy81 wrote:Hi Rob,
Looking very good!
Jordan
It's out of an rx7 gsl... posi... rear disc..
3:90 gears
Thanks!
Rob
Looking good Rob!!
Have you gotten to the point of sorting the air filter and will it fit under the hood?
- v6spider
Thanks!SoFlaFiat wrote:Looking good Rob!!
The air cleaner is still a work in progress... But I have 2.5" clearance to play with.
Rob
I know it's a personal thing but I'll say it anyway, I love a sleeper! If you are of the same thought process, judging by what I have seen, you will find a way to keep it under the stock hood. Snorkel?
Keep it up Rob! Looks like you are getting close!
- v6spider
Thanks Man I appreciate it! Yes I want a sleeper absolutely! The first version of v6spider had a big hilborn scoop popping out the hood and I tell you every rice grinder within eye shot were rapping out their chainsaw sounding engines!SoFlaFiat wrote:I know it's a personal thing but I'll say it anyway, I love a sleeper! If you are of the same thought process, judging by what I have seen, you will find a way to keep it under the stock hood. Snorkel?
Rob
