new top
veloce
new top
Post by veloce »
Hi guys i am one those guy that asks and never ansewr any questions (because have not much knoledge) I just had a new top installed and i was thinking covering the ribs covered by the canvas with some kind OF SLIT TUBING to protect the gluted canvas,any ideas ,THANK YOU IN ADVANCE
124JOE
Re: new top
Post by 124JOE »
thats how they come from the factory
the tubing helps hold the top down
veloce
Re: new top
Post by veloce »
HI 124 JOE any idea where to get the original parts or something that can replace it Thanks
124JOE
Re: new top
Post by 124JOE »
i got my tubes from a parts car
you can look at a junkyard
or ask the vendors
alisonautomotive
autoricrombi
vickautosprts
mrfiat
veloce
Re: new top
Post by veloce »
I got an other idea by you a 1/2 poly irrigation black tubing 50' for $8 the only thing you do split it
124JOE
Re: new top
Post by 124JOE »
yes that will work
build a jig
drill a hole in a 2x4 and mount a razor blade in it to cut the slit
then push the tube in and pull it out the other side
