Trunk Board and Carpet w/Pics
Foster48x
Post by Foster48x »
I finally finished up the replacement trunk boards for my 80 FI. Without existing boards to use as a template it turned out to be fairly challenging to get all of the curved cuts right. All in all though I think it turned out pretty good. I still need to install the two metal pieces that support the right and left bottom boards and the plastic cover that goes over the fuel lines. Even without it for now the boards are pretty stable. Here are some pics.
Material used was a project type board from the local hardware store.
Cut tight around the battery box so the lip of the box is used as support.
Around Fuel Lines
I cut the back of the side board a little long (not really sure why). I may need the extra length when I install the carpet. If not I may cut it down a little.
1x2 Support for the left side board. I left about ¾ of an inch on each side of the 1x2 to create a lip. One side goes over the edge of the battery box and the other on the back lip of the trunk.
Template
Carpet install is coming soon.
Rick
Foster48x
Re: Trunk Board and Carpet w/Pics
Post by Foster48x »
I finally got the trunk carpet cut this weekend. Here’s how it came out.
Bonus! I was digging around in some old parts and found one of these.
Rick
burgandy81
Your car is a: 1981 FIAT Spider 2000
Post by burgandy81 »
Hand held way up!
Thanks!
Jordan
PM sent
Fiat88
Post by Fiat88 »
Great post!
engineerted
Post by engineerted »
Wow! there are boards for the side? I did not know that.
Ted
Ted
azygoustoyou
Post by azygoustoyou »
Great work Rick! :P
Foster48x
Post by Foster48x »
engineerted wrote:Wow! there are boards for the side? I did not know that.
Ted
Neither did I :D No one could tell me how the carpet attached to the sides to cover the jack and fuel lines so I just closed it in to give it a cleaner look when the carpets installed.
Rick
Ozzie4208
Post by Ozzie4208 »
Hey Rick,
My carpet only covers the boards in the trunk. The carpet just lays on top of the boards. I also don't have any side boards on my 79. just the ones on the bottom. I hope this helps. Excellent job on the boards they look great.
Dave
Foster48x
Post by Foster48x »
Thanks Dave. I figured that was the case after seeing some pics of the original boards but wasn't for sure. I was prompted to do the side boards after seeing some pics of the original carpet. It looks like it goes up the side of trunk. I couldn't figure out how to attach it to the sides so I made the boards to support it.
Rick
jfrawley
Your car is a: 1982 Spider
Post by jfrawley »
In my '82 the carpet is attached to the side boards only and just rests on the bottom sections. The drivers side board attaches with a small sheet metal screw at the top and the passengers side has a small gromet in it that goes over a connector on the car that has a twist closure. The carpet comes out as one piece with the two side boards attached.
Hope that helps.
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
Foster48x
Post by Foster48x »
John,
That helps allot! You wouln't happen to have pics of the passenger side board/carpet where the grommet attaches to the side of the trunk? I'm also wondering... is the carpet glued to the side boards on your car?
Rick
jfrawley
Post by jfrawley »
Yes, the carpet is glued to the side boards, but not the bottom boards. I'll take a pic or two when I get home tonight.
John Frawley
Frederick, MD
1982 Spider
jfrawley
Post by jfrawley »
Ok, here you go.
Passengers side board fastened in place:
Fastener:
How the carpet is glued on to the side board:
Hope this helps.
John Frawley
Frederick, MD
1982 Spider
Foster48x
Post by Foster48x »
Purfect! Thanks for the pics John.
Rick
Foster48x
Post by Foster48x »
Original post has been updated with pics of the carpet.
Rick
