In response to Clark's suggestion about swapping the carb for fuel injection.. the cam is too big apparently to run EFI and according to the manufacturer is not recommended. So I am sticking with the Carter AFB I tuned for the first version of v6spider..
Rob
V6 coming together...
- v6spider
Re: V6 coming together...
http://www.v6spider.com
- v6spider
Timing cover installed, cam end play adjusted, roller lifters adjusted, water pump installed, intake and carb installed. I just discovered a crack in my harmonic balancer, so I'll have to replace it. Real close to being done though...
Rob
Rob
Not bad at all considering its twice the size in displacement.
v6spider wrote: Lanciahf: the heads and block are cast iron. Whole engine is only 75lbs heavier than the 2L twin cam plus I moved the battery to the trunk.
Rob
- v6spider
Over 3 times the hp too..lanciahf wrote:Not bad at all considering its twice the size in displacement.
Cheers!
Rob
- v6spider
Talked with my machine shop this afternoon ...with the vortec heads and four relief flat top pistons compression will be around 10.5:1... pushing the limits there.. ignition timing will have to be set advanced 15°+ with cam specs I'm running...
