now the fun begins..
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Re: now the fun begins..
Post by v6spider »
SoFlaFiat wrote:Just curious Rob, are you planning a lever or pulley system to route the cable back or are you bringing it through the firewall on the passengers side?
Well done!!
Thanks! I'm going to route a cable to a custom pull that will mount into an existing location under the dash...I also need move the brake booster to the left away from the engine, create indentation in the oil pan to clear the rack and do some cutting of the excess sheet metal around the shifter.
Cheers!
Rob
http://www.v6spider.com
SoFlaFiat
Post by SoFlaFiat »
Like you said, now the fun begins!
Keep it up!!
v6spider
Post by v6spider »
SoFlaFiat wrote:Like you said, now the fun begins!
Keep it up!!
I live for it! I was noticing last night how flexible the firewall is around the clutch cable hole. I am also going to reinforce that area as well.
Rob
SoFlaFiat
Post by SoFlaFiat »
I have not personally experienced that issue but I have read about it several times on the forum. As with everything else you are doing Rob, nows the time!
v6spider
Post by v6spider »
SoFlaFiat wrote:I have not personally experienced that issue but I have read about it several times on the forum. As with everything else you are doing Rob, nows the time!
The clutch setup I'm using is stiffer than the stock spider clutch..so is an absolute necessity I beef that up.
And yes I've heard of issues with it braking around hole.
Cheers!
Rob
