now, this stuff can be fun and or frustrating at times but pays the bills. So my buddy wanted a Really nice Stereo
in his Car since I've installed some systems for him in the past he felt like trusting my judgement on his this
project he let me choose what i wanted to put in his pride and joy.
So far I've installed a few things tomorrow should be closer to the finish line friday completed.
I'm installing 6 Morel 1 1/8" Tweeters, a 5 1/4" Mid in the dash, 12" Sub in a custom built 4th order band pass
box, assembling many Crossovers some 12db designs some band pass, running a 6 inch port through the rear seat
arm rest. We are using two 4 channel Amps feed from his factory Radio with Ipod control and Sat Radio A 4 Ferret
Stiffening Capacitor and a Audio Control high to low Controller/ EQ. All this will feed 6 Tweeters 5 Mids the factory
8 inch dual channel Sub and a 12" Sub. I so wish i had this setup myself maybe next year
are a few photos of what is done so far.
On the Crossovers I designed them to filter out the highs feeding the Factory Mids and 8inch Sub. On the Caps
for the Tweeters I'm using what is considered fast capacitors these have a faster response time then most. This
should help bring the smoothness of the Soft dome style tweeters to life with a little more crisp sound. The 8 inch
Sub is used for mid bass only running from 100 Hz to 250 Hz. The Memphis Sound 12" is going to run from 35 Hz
to 96 Hz but the effective range within the tuning from the port is between 40 Hz to 75 Hz having a linear equation
on bass tones within the musics reproductive response.
