I just finished an install of an Audiovox Ultracruise II unit, in my 73. Overall, it went fairly well. There are a couple of errors/inconsistencies in the Audiovox installation manual, but I figured it out mostly. The unit I installed doesn't need a vacuum line, as it has the electronic controlled servo built in.
I ended up removing the throttle cable and knob from below the steering wheel, and reusing that fitting and opening for the cruise control cable - it seemed almost a perfect use for an unused feature. I ended up installing the interrupter switch on the brake pedal rather than the clutch pedal, as the switch for the clutch electro-valve would have interfered with the cruise control switch. I did have to make a custom bracket to mount the switch assembly, and it was tricky to get the alignment correct for the switch to work, but all in all, it wasn't that bad of a job.
Now I have beautiful, perfect cruise control, like in a modern vehicle. I did install the control switch into the front ashtray, behind the stick shift, as another fiatspider.com member had done. Any questions, send me a note.
cruise control.
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- Announcements & News
- ↳ Important: Read BEFORE you register!
- ↳ FORUM RULES
- ↳ DONATIONS - Support This Site
- General Discussion
- ↳ New Members / Introductions
- ↳ Fiat Spider Related
- ↳ Off Topic & Social
- ↳ Fiat Spider Events
- ↳ Related Web Links
- ↳ NEW 124 SPIDER
- Technical Area
- ↳ Engine and Tuning
- ↳ Electrical Issues
- ↳ Suspension Related
- ↳ Wheels and Tires
- ↳ Custom Stuff
- ↳ General Maintenance
- ↳ Cosmetics
- ↳ Performance
- ↳ Restoration Projects
- Sponsor Vendor Forums
- ↳ Vick Autosports
- Classifieds / For Sale
- ↳ Cars For Sale
- ↳ Parts For Sale
- ↳ Cars/Parts Wanted
- Web Site Feedback
- ↳ Discussions About This Site
- CLUB FORUMS
- ↳ Chi-FLU
- ↳ So Cal FLU
- ↳ WEST MICHIGAN FLU
- ↳ Utah Spider Association
- Other Fiat Models
- ↳ The NEW Fiat 500
- ↳ Everything Fiat 850
