can I install 3 point Seat belt in a 76 spider
RAD
Post by RAD »
I have a 1976 spider 124 I would like to install a three point Seat belt (lap and shoulder). is this possible? If so where would the higher shoulder mount go?
csi2000s
Re: can I install 3 point Seat belt in a 76 spider
Post by csi2000s »
You can fit 3 point seat belts no problem. The later models of spiders have seat belt guides which mount to the side from the head rests to guide the belt over the shoulder. To fit retractable belts you will need to make brackets and weld them in to mount the seat belt unit behind the seats. The rear seat will need to have the plastic slots fitted to your rear seat so the seat belt can slide through. You can get these on ebay as well as the guides.
Check out this link for the guides from Alisons Automotive
http://www.ebay.com.au/itm/FIAT-124-SPI ... 4d12c9b3b1
aj81spider
Post by aj81spider »
I converted my 74 to 3 point belts. A thread on conversion is:
http://www.fiatspider.com/f08/viewtopic ... lt#p211270
A.J.
2006 Corvette
