So... The master cylinder finally showed up. Brakes are bled, life is good. Still things need refining.. Front Alignment, then clutch needs a better fitting cable. I may modify a 5.0 mustang clutch arm to work with the camaro t5 I'm using as the mustang one is stronger than the Monza one and also is straight. Instead of having a curve in it which will take up some of the slack in the cable so I won't need so many spacers.. Once I'm done testing I'll finish up with the body work and paint. I'm also building a custom console.
Otherwise, having fun with it!
Cheers!
Rob
V6spider out on the road..
- v6spider
http://www.v6spider.com
Re: V6spider out on the road..
Congratulations persevering with this gigantic project
- v6spider
I've been at it over 14 years! This one is much better than the first. Still more to go.. Appreciate your kind words!baltobernie wrote:Congratulations persevering with this gigantic project
Cheers!
Rob
