Single din with motorized screen
- Your car is a: 124AS 1969 Fiat Spider
I'm restoring a 69 spider that has the standard dash with the extended " pad" above the radio wich extends from driver to passenger driver side. Is there a particular brand of stereo that will clear this when open that I can purchase and install? Thanks. Gregory
- 81SPIDERMATT
Re: Single din with motorized screen
don't they have ones that come out and down instead of up .... thought my friend had one like that because he had the same issue (not a fiat)
But someone has got the one to fit right? There must be an answer. Please
- toplessexpat
I've often wondered if something like this would work.
http://www.onlinecarstereo.com/CarAudio ... -500.aspxQ
Not motorized, but hangs down a little and looks large enough to use... I would fear a motorized screen would interfere with gearbox movement potentially.... and if you tilted the screen would definitely get in the way....
A
A
- 124JOE
what if you made a sleve that makes it stick out about an inch?
and still looks good.joe
There are ones on eBay, not name brands but there is one adjustable one and it goes down instead of up I have thought about getting it but not sure about the brand Dual..
Edit: this one I found just typing in the search "single din touch screen"
http://m.ebay.com/itm/131327547298?nav=SEARCH
