re gluing side morror latch
grasshopper
Your car is a: 1976 Fiat Spider
Post by grasshopper »
Hi guys. Has anyone had success re gluing the lock mechanism back onto the little triangle vent windows ? I also have a little chip of glass missing from where it mounts. Must have chipped off when the latch fell off,,,
Any ideas on adhesives ,,etc,,?
focodave
Re: re gluing side morror latch
Post by focodave »
This is what you want:
https://www.acehardware.com/departments ... atch%20All
Available from numerous suppliers...
1970 MGB GT (my other hobby)
scrapironchef
Your car is a: 79 Spider
Post by scrapironchef »
They belong in the map pockets on the kick panels, they are only glued to the window as a shipping position from the factory.
wetminkey
Post by wetminkey »
Ha! It is only a convertible.
Latches, they're kinda like door locks in a convertible, they function to hold position only,...
Latches!?,...who needs latches?!
Actually, I do like mine to be in place, and functional. But they are a PITA, huh!?
My driver's came back off, but I did not use 100% alcohol to clean. I think the RapidFix is the answer,...chips/irregularities can be filled with the powder that comes with it.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
focodave
Post by focodave »
...and if you don't feel like paying for the Rapid Fix, you can use any cyanoacrylate glue (Super Glue) and baking soda.
The magic welding powder in the Rapid Fix is either baking soda or very similar to baking soda.
If you use baking soda, you will want to pulverize it as fine as you can to make it more "powdery".
Post by RRoller123 »
I wonder if roughening up the glass at the adhesion area would help. A Dremel with a small ceramic bit would probably do it.
DieselSpider
Post by DieselSpider »
RRoller123 wrote:I wonder if roughening up the glass at the adhesion area would help. A Dremel with a small ceramic bit would probably do it.
Maybe but it may also promote spider cracks radiating out from the scoring of the glass.
Perhaps, but not scoring, just roughen the surface up a little with some sandpaper. Even glass with a deep scratch rarely extends. If it is broken all the way through, sure, but I would be very surprised if sanding a small dot sized surface causes any greater problem?
Ragno124
Your car is a: 1981 124 Spider
Post by Ragno124 »
In my case, multiple attempts to reattach resulted in both vent latches delaminating part of the glass when they last came off. So the better glue doesn't equal better glass. Latches now reside in my glove box where they will stay forever with two small chips in the vent glass.
Steve Muzzillo
1981 124 Spider 2000 (ex-turbo)
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
