Flare Nut Wrench for Brakes
Anybody know off hand was size Flare Nut Wrenches are needed to work on Fiat brake lines?
Re: Flare Nut Wrench for Brakes
a 10mm wrench should to the job
- TulsaSpider
I use a pair of vise grips as well over the flare nut, keeps it's shape, usually works
- Kevin1
Get a pair of v-groove vice grip pliers. I haven't met a flare nut it couldn't conquer, no matter how old and crusty, even if they have been rounded off before. One of my favorite tools.
http://www.irwin.com/tools/locking-tool ... g-wrenches
I would think that Vise-Grips would distort the nut, rendering it useless. But if you were planning on replacing the brake hose anyway ...
While we're on the subject, does anybody use anti-seize on the bleeder screws?
- TulsaSpider
No you mis understand. I put the vise grips on the outside of the flare wrench fairly lightly. It keeps the flare wrench from distorting and bending and rounding off the nut.
- wachuko
- Contact:
Problem with our brake lines is that the coating on the line corrodes and freezes the nut on the line... do not ask me how I know.
Good quality flare nut wrench, if the lines are in good condition, should do the trick.
I like the idea of the vise grips on the outside of the flare wrench, but it must be a pita in some of the tight spaces...
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
I like the looks of this tool! I can see how it would help:Kevin1 wrote:Get a pair of v-groove vice grip pliers. I haven't met a flare nut it couldn't conquer, no matter how old and crusty, even if they have been rounded off before. One of my favorite tools.
![Image](http://www.irwin.com/uploads/products/large/the-original%E2%84%A2-locking-wrenches-302.jpg)
I use antisieze on everything I know I'll have to do over again, so yeah.
![Confused :?](./images/smilies/icon_confused.gif)
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- Your car is a: 1975 124 Spider + 1974 X19
Folks, Kevin1 is right. The vicegrip tool works BETTER than even a quality flarenut wrench. terry
here's info on a new flare nut wrench that looks promising
http://directory.pten.com/product/10207 ... t_No_FF204
I might be ordering one of those, especially after the trouble I went through removing the lines on my X19. My Craftsman tools were just plain disappointing and there just isn't any room to add vice grips in the mix.coopertl wrote:Folks, Kevin1 is right. The vicegrip tool works BETTER than even a quality flarenut wrench. terry
Does anyone have a set of Snap-Ons they can report on? Do they spread out and lose their grip or are they worth the extra money?
Like many,the brake fittings have been a source of frustration till I bought a flared wrench. I combine the wrench with fire if the thing does not break loose with some effort. I use that meps gas, seems a bit hotter than the usual blue bottle stuff. So far so good.
Chris
Chris
My snap-on tubing wrenches are wonderful, worth every cent.
Heat, penetrating oil, then tap on line, and nut. Keep it up. can't remember the last time I had a line I couldn't get undone easily.
Vise Grips just distort the crap out of everything and basicly pinch the nut onto the line. Last resort.
Like many of us I have also ruined the flare nuts using vise grips. I'm always a little leary of applying heat to losen up the nut. I have two set s of flare nut wrenches. One is worthless and you can not apply much force without the wrench opening. It was a cheap set that I picked up at Autozone to get a job done in a hurry. Obviously a poor choice on my part. The second set is snap on. They work well and have a wider putting more metal around the nut to eliminate/reduce the destortion of the nut as well as not altering the wrench. The nuts are a softer metal and therefore are prone to distort quickly. The 6 piece metric Snap on set was a purchased used for $45 from my neighbor. I have seen the same set with various prices and that set is always north of $150. Ray
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
