Has anyone ever rebuilt their wiring harness? What connectors did you use, wire wrapping materials etc...?
Thanks!
Rob
Notes and photos are to help out forum members, not the next owners of your car. The Painless harness has the wire function and number printed repeatedly over the entire length of each wire. Then there's also the manual, which identifies what went where. Painless also uses a lot more colors than Fiat ever did.v6spider wrote:Baltobernie: Wont be ever selling my spider...keeping the stock colors for the wire will help with tracing issues.
Ok. that makes sense. The TXL is in fact an XLPE (Cross-Link-Polyethylene) wire, which to guys in the building-wire business (which I sometiems am) is good stuff.baltobernie wrote:Maytag, the standard for automotive wire is SAE J1128. OEMs (and Painless, among others) use "TXL" spec wire with a polyethylene jacket. Not only is it incredibly strong, it is very small in diameter (because of all the wire in modern cars). 18 AWG, for example, is only 2mm in OD. The new stuff is soooo flexible, it is a delight to work with. For suggested wire gauge for specific circuits, you could look at a Painless or other harness installation manual, and use what they use.
