Exhaust sounds.
Danno
Exhaust sounds.
Post by Danno »
OK, I'll have to update with pictures at some point, but for now here are the sounds.
sounds were recording as follows:
1. Stand at passenger door, hold recorder at about window height. then after several seconds (10ish) move the recorder near to the exhaust exit. Placement is out of line with the exit, about 6" away at about 45 degrees.
2. second sound file for each is the sound of the car at idle recorded from the interior with the top up. Other things to note are that my doors have no insulation or interior panel. Also, I have installed new sound/thermo insulation on the floor. i think I documented that last year some time.
This first set is the sound of NO EXHAUST:
outside car: http://www.danielreinhardt.com/fiat/EXHAUST_5.wav
inside car: http://www.danielreinhardt.com/fiat/EXHAUST_6.wav
Second set is of this cheap muffler I bought at the local farm supply type store. It is 2" inlet and 2" outlet.
outside car: http://www.danielreinhardt.com/fiat/EXHAUST_3.wav
inside car: http://www.danielreinhardt.com/fiat/EXHAUST_4.wav
Final sound set is of the muffler described above PLUS a straight through 2.5" inlet 2.5" outlet muffler from ebay a couple of years ago.
outside car: http://www.danielreinhardt.com/fiat/EXHAUST_1.wav
inside car: http://www.danielreinhardt.com/fiat/EXHAUST_2.wav
Decision was to go with the final setup, it sounds the best by far. There is a tin-y note to the cheap exhaust only, the straight through exhaust added seems to leave the low sounds alone while taking the high sounds, volume between the two isn't much different.
The exhaust currently exits in front of the RP tire, clamps, adaptors, a 90 degree pipe for exit, the two mufflers set me back about (listed in order) 2+2+2+2+2+9+25+25=70 bucks(-ish).
Mark_vaughn
Post by Mark_vaughn »
The sound files are not working.
mbouse
Post by mbouse »
mee too. don't work.
really quiet!
Danno
Post by Danno »
sorry guys, i don't know what the prob is. I just tried and it wouldn't work for me either. the files are on my other laptop, i'll have to work on uploading them again....
DMECMAnderson
Post by DMECMAnderson »
Heck I thought there was something wrong with my system.... :?
Danno
Post by Danno »
DMECMAnderson wrote:Heck I thought there was something wrong with my system.... :?
nope it's not you; each file is 0Kb so I'm guessing there was an upload problem.
Danno
Post by Danno »
OK, give it another try, i think I fixed it.
mbouse
Post by mbouse »
ummm..... did the birds come with the Ebay muffler, or did you install them separately?
har har
Danno
Post by Danno »
mbouse wrote:ummm..... did the birds come with the Ebay muffler, or did you install them separately?
har har
what birds? have you been whacked on the head? No, just kidding. those birds were driving me crazy that day. I don't know where the came from, but a flock of a couple hundred decided to park for about 2 hours in my tree. when I did the sound recording most had flown away, so you can only imagine how it sounded before!
