avatar
- 124JOE
Re: avatar
i dont get it ether
i shrunk it smaller and smaller
and still too large????
- Razooli
- Your car is a: 1982 Fiat Spider 2000
Re: avatar
Maximum dimensions; width: 80 pixels, height: 80 pixels, file size: 6kB.
For example, mine is 60 px x 59 px
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
1982 Spider 2000
- 124JOE
Re: avatar
i was trying to re size it in photobucket,but failed
- 124ADDHE
Re: avatar
If you have "Paint" on your computer, you can use this to resize.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- 124JOE
Re: avatar
thanks i do and ill try
Re: avatar
you may need to reshoot your picture in a low res format to get it down to this puny of a picture. I have a photo editor i got with a scanner. If you want, send me the pix and i will see how small i can get it.
- 124JOE
Re: avatar
but i think its too blurry
this one is better
- MrWampus
- Your car is a: 1981 Spider
Re: avatar
Yeah, I think I'm doing something wrong too. In order to get my avatar pic below the 6k threshold, I had to save it in .gif format which makes it very grainy. I see others with nice clear pics. The smallest I could get mine in 80 x 60 in jpeg format was still something like 31k. Am I missing something?
1981 Spider "The Mistress"
http://s1088.photobucket.com/albums/i329/mrwampus1/
"Because a 30-year-old sports car is cheaper than a 30-year-old blonde."
- Razooli
Re: avatar
How I did it:MrWampus wrote:Yeah, I think I'm doing something wrong too. In order to get my avatar pic below the 6k threshold, I had to save it in .gif format which makes it very grainy. I see others with nice clear pics. The smallest I could get mine in 80 x 60 in jpeg format was still something like 31k. Am I missing something?
Download the IrfanView program and Plug-in package (homepage http://www.irfanview.com, also on Tucows, CNET, etc. and it's free), install and load the file. Under Image ... Resize,Resample... check Preserve aspect ratio and Sharpen after resize. In the DPI box, enter 300. Select Set new size ... enter in 80 x 80. The entries will auto adjust with the longest side being 80 pixels depending on whether the pic is portrait or landscape. Press OK. Then File ... Save as ... , enter a new filename (you don't want to overwrite the original) and on the JPEG/GIF save options flyout that will appear, select Set file size: and enter 6.0. Hit Save and you're done. You have to install the Plug-in package along with the main program to get the ability to set the file size.
Sounds complicated, I know ... but it's really easy, and if you do any manipulation of photos at all, it's an invaluable program. I've used it since Win98, probably once a day at least. Much faster than loading my full photo editing software.
Here you go, Joe .... 80x60, 6kb
Lynn Shuler
1982 Spider 2000
1982 Spider 2000
- 124JOE
Re: avatar
thanks man ill keep trying
mabey ill get one we can read
- Razooli
Re: avatar
Lynn Shuler
1982 Spider 2000
1982 Spider 2000
