After installing two tops on Saturday the first thing I have to say for those on the fence of making this a diy, don't be afraid. It is actually something mere mortals can do. Works best if you have a friend helping out.
The two articles posted before are your best guide. So I am not going to rewrite what they have done. I will just compliment with a few photos we took along the way.
Here's a link to Chris Obert's installation guide.
http://www.fiatplus.com/members/tech200.htm
Plus International-Auto (IAP) has these steps in their site as well...
http://www.international-auto.com/fiat- ... lation.cfm
Remove rear molding around inside of rear top well. This is the metal molding covered in vinyl that is inside in the back. At the bottom of the top. Six screws holds it in place... here is a photo of it removed:
If your car is a 2–liter, remove the three plastic covers on the center bows. Put them aside because you'll need to put them back on when you're done.
Loosen bolts holding rear anchor bar down. Push this bar up until you can remove top from underneath. Not need to remove it. Loosen all screws and slide up.
Pull the top up and off of the front bow far enough on the edges to remove the side wires from around the small posts. Loosen screws holding cable. Pull cables from old top, unglue bow strips from all three bows and remove top from car.
Loosen top in front and remove screws holding rubber molding in place. Remove rubber molding and remove glue strip from front bow, being careful not to tear bow covering.
At this point we decided to fix the cover on the front bow. Some spray adhesive (3M) and some clamps did the trick.
Drill out the rivets from inside the window flaps using a 1/8 (0.125 ) drill. There are three on each side - one in front, two in quarter windows.
I forgot to take photos before drilling these out... so I will just show their location with the photos of the new ones installed...
