Do I need new calipers, why arent they going back in.?
If any one has had experience of this could you put me out of my misery.
Andy
I'm actually frustrating with the same D^*N thing myself this evening. (mine are on a '76.)narfire wrote:They do screw in when the e brake is applied. Then the spring washers unscrew the rod/piston when the handbrake is let off.
ok... no. I'm not sure. they "fit" into the holder. But are you saying they are thicker? I didn't even think to check that. SUNNUVA!!!spiderrey wrote:Are you sure you have the right pads? Fronts dont fit on the rear. The piston fully compressed should be flush with the caliper.
