Rebuilding - help and pointers
ch33kster
Post by ch33kster »
Hi, just in the process of rebuilding my Fiat back together.
Just wanted to know if anybody had any help and pointers to save time and prevent niggly issues later on after door cards, carpet and seating have been put back in.
JeremyB
Re: Rebuilding - help and pointers
Post by JeremyB »
Hi! You are farther along than I am. I havent started on the interior yet. One thing I have heard of peopl edoing is to put a layer of sound deadening between the floorboards, and carpeting.
Is this the type of ideas you are lokoing for?
mbouse
Post by mbouse »
if you need to remove the pedals, now is the time to reinforce the forks on the clutch pedal.
ch33kster
Post by ch33kster »
mbouse wrote:if you need to remove the pedals, now is the time to reinforce the forks on the clutch pedal.
Please explain. Currently getting to the stage of dealing with the interior and pedals are ijn location but easy to get too.
mdrburchette
Post by mdrburchette »
The clutch pedal has forks that the clutch cable attaches to. Sometimes these will bend so many of us have reinforced them to keep them from bending if the cable binds. Another maintenance repair is to weld an extra square of metal to the firewall where the cable comes through to keep the firewall from cracking. I did both on mine only because I used a racing clutch that requires extra leg muscle to work, but I have seen a firewall fail in this area with a stock clutch setup.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
