Strange rear end fluid leak
beater
Post by beater »
In the spring when I first moved my Spider after winter storage I noticed a relatively large puddle under the rear end. I noticed no leakage throughout the preceding summer.
This past summer I changed the fluid in the rear end and ran it most of the summer and noticed no leaks at all. About 2 weeks ago I back the car into the corner of the garage where it resides for the winter and when I went in the garage tonite I detected a heavy oil smell and looked underneath and sure enough the rear end had leaked on the floor. I will take a look at seals but I find it very odd that it did not leak during or between uses all summer and then leaked when left idle.
Anyone else ever experience this, I have to wonder if temp has something to do with it?
kmead
Re: Strange rear end fluid leak
Post by kmead »
You might consider whether its a brake fluid leak. Either caliper, the flex hoses or the compensator could all be the source of the leak.
That or something keeps spilling in your trunk whenever you stick it into that corner.
Karl
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
fiasco
Post by fiasco »
I had a bad seal on the diff last year. The more I drove it, the less it leaked. The longer it sat, the more it leaked. I assume that when it got warm, the leak in the gasket closed up a bit, and when it cooled down, it opened up again. Unlike yours, mine leaked all the time, just more when idle and less when driven.
-- se
Steve Eubanks
beater
Post by beater »
That's a good thought really. Maybe it is the cold making the seal contract. I've changed the axle seals (that was a hell of a job) but I've never changed the pinion seal. Looks like another spring job :(
surfingfreeman
Your car is a: 1982 2000 FI
Post by surfingfreeman »
Too much coffee?
tartan18
Post by tartan18 »
In my case the leak was brake fluid. Ended up replacing all brake components including both hard and soft lines, booster, calipers, etc. Christmas helpers were a bonus :-)
Jim MacKenzie
1975 Fiat Spider
beater
Post by beater »
I really don't think it's brake fluid based on the smell and viscosity of the liquid. Also all my calipers and lines are new as of 10 years ago and I have had 0 brake issues.
