New vs Old Rear End
New vs Old Rear End
Hey all,
I was just wondering, is it an easy swap to put a late model rear end into an early car? My fiat originally came with the old style rear end and I can get my hands on the new style rear end for free.
Mike
Mike
Re: New vs Old Rear End
Do it, you won't be sorry.
You need the driveshaft and the pitman arm from the donor car. Also the brake backing plates are different too.
Easy swap. Of course you can do the springs and shocks while you are there, and the brakes will be apart as well.
Search the forum there's a write up somewhere. If you go ahead you can PM me if you want for more specific details.
You meant the panhard rod. The pitman arm is the arm for the steering box.
The driveshaft length is different by 10 mm, but usually there is enough play in the front slider to make up for it, but the center support needs to be loosened and allowed to find its new place - if the rubber is distorted ten the holes may need to be slotted so it can move in a 'rest' position where the rubber is not stretched toward the back or the front.
Oh my, Is that why my Spider steers from the back?vandor wrote:You meant the panhard rod. The pitman arm is the arm for the steering box.
Thanks Vandor for that minor correction.
You also need the donor rear hard brake line, it's different than the early one. I found that out the hard way.
Thanks for the replies. I just bought this car last spring and replaced the springs and shocks and did the brakes over the summer so I will just be reusing those. I mostly was just worried about the actual fitment of the rear end as a whole. I wasn't sure if it used the same mounting points and everything. I can also get my hands on the drive shaft that goes with the new rear end so I guess I might as well replace that while I have it apart. Thanks for the help!
Every time I follow a Honda CRV, I notice that car's independent rear suspension has roughly the same track as my Spider. If I were swapping rear ends, that would be a tempting change -- if I had the means to do it.
Has anyone else put an independent rear end in a Fiat Spider?
I've always had dreams of a miata rear. Supposedly the whole rear sub frame on those is held in by a couple bolts
Abarth![Smile :-)](./images/smilies/icon_smile.gif)
I have thought about a Miata rear too, it really depends on the size of the Miata subframe - I think it's too big for the Spider.
The other question is, at that point why not just buy a Miata?![Smile :-)](./images/smilies/icon_smile.gif)
Abarth
No guy's, don't say the M-word here
You know what is about to happen now, don't you?!
![Shocked :shock:](./images/smilies/icon_eek.gif)
Don't do it, Jay!!!
NO!!!! DON'T ENCOURAGE HIM!!!
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
