1980 Spider brakes
Danno
1980 Spider brakes
Post by Danno »
Well, I thought it had drums in the rear. am I wrong, are their disc brakes in the rear? the catalog has calipers, and whatnot so I'm assuming it's the disc setup for the rear too. it's the same rotor for front and rear?
thanks for the help.
Joe Clemente
Post by Joe Clemente »
Danno,
Am I safe in assuming that you have just bought your Spider? This is your first? Drums? :?
To answer your question, yes, they all have rear discs, came standard.
The discs are the same front and rear. The front calipers and rear calipers are not the same. The fronts have a 48mm bore, the rear calipers have a 34mm bore.
Joe
Danno
Post by Danno »
wel, yeah, it's my first, and I hear what you are saying. I haven't pulled off the hubcap/wheel to see what's under there, just looked at manuals and catalogs. I said drum because in my owners manual it says (under Brakes)
Front: disk type , with floating caliper and one cylinder to each wheel.
Rear: self-centering, expanding-shoe drum type, with one cylinder to each wheel.
so I'm sure you can see why I thought that!
you must not be reading a 124 Spider catalog, they all came with 4 whl discs
Joe Clemente
No problem Danno,
Get her up and running soon...
Cheers!
Danno
Post by Danno »
So Cal Mark wrote:you must not be reading a 124 Spider catalog, they all came with 4 whl discs
I'm getting this info from the owner's manual. it says Fiat Spider - 2000 (Carburetor System) on the front page. well, anyway, if you guys tell me it has 4wheel discs then cool! wonder why the owner's manual says otherwise?
Danno
Post by Danno »
just to show y'all I'm not nuts here's the manual, and to show that the manual is wrong here's a pic of my fiat's rear brakes....
wow, that's amazing. I'll have to look at some other manuals and see if Fiat printed that in all of them. That would describe the Brava/131 brake system
