Blinker kit from mark
Where do most people mount this lights, I'm bumper less
- 81SPIDERMATT
Re: Blinker kit from mark
i used the oval holes.... they need to be "wallered out" a bit
Ok great, so they need to be a bit bigger81SPIDERMATT wrote:i used the oval holes.... they need to be "wallered out" a bit
- 81SPIDERMATT
you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
Thanks, i have them. I just have not looked at them yet. I seems to loose stuff in my garage.81SPIDERMATT wrote:you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
What did you use to cut it out
- 81SPIDERMATT
i used some type of grinding thing that fit in my drill... looked like a small barrel .... the guy at ace said it would work... not a whole lot needs to be removed.... did not trust my abilities with my big grinder tryiing to finesse a cut in that small space.... worried that i would cut too much or catch and run a big scratch.... and the sawzall seem to be overkill
i seen that not much needs to be removed
how did u fasten that light? what did you use on the back side?
the light has a cup that mounts from the back side to secure the light
Ok I was thinking that's how it would go, but was not positive, thanksSo Cal Mark wrote:the light has a cup that mounts from the back side to secure the light
And I got to buy my own nuts? Lol
- SLOSpider
Don't JACK UP that light install
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
with a Dremel or similar grinder, remove a slight amount of metal from the top and bottom of each bumper shock hole. The rubber grommet will fill the gaps around the edges of the lights.
- toplessexpat
- Your car is a: 1976 Spider 1800
While there's nothing wrong with the blinker light kit ...
... I elected to fit some custom truck headlamps with integrated LED blinkers in the the bottom 10mm or so. There's also a row of LEDs for the park lights.
Ping me if you'd like pictures - on the Texas Hill Country run a couple of weeks back, people saw mine and weren't overly critical
Andy
Andy
- SLOSpider
Post up some pics topless
1975 124 Spider
