Rear brake pistons
Rear brake pistons
Changing out the pads/rotors on the rear of my '79 and I need to get the pistons retracted back in - I forget if they both get screwed back in CW or if one is CW and the other is CCW.
Re: Rear brake pistons
Thanks, I finally got it - Had to rig up a tool to screw them in with. The driver's side was tough to screw in but the pass side was a breeze.
- Your car is a: 1975 Spider
then you maybe are going to have a caliper problem, if it goes in hard, then there is a seal issue or a brake hose not letting pressure out, check the temperature of that rotor vs the one on the other side after you drive it a bit,
son has 78 spider
son has 78 spider
Sorry for hacking
But when u install the rear,do u screw them all the way in to slide them over the pads,just so there snug
I screw them in as far as they will go.fiat218 wrote:Sorry for hacking
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
