I have a new GPS speedo winging its way from Andytach.com now the item I have ordered is 52mm. I ordered it so I can see the speedo in kph and not the MPH as it currently shows.
Now to my question. As the clock has bad glaucoma, my devious mind is considering the following:
Removing the non working clock. Moving the oil gage to the location of the clock. and mounting the new shiney GPS speedo front and center in the spot previously occupied by the oil gauge.
So before the dash is removed does anyone know the diameter of the holes in question? Will the oil gauge slip direct into the clock location, and will a 52mm add in slide into the location of the Oil pressure?
Any help would be very greatly appreciated.
Have a great day one and all and safe driving.
Ian
