Ok, I'm going to start slow and work into a frenzy of " What the hell is this thing?" and "How do I fix that thing?" questions. I'm so happy I found this site and seem to be spending more and more time reading and learning about my spider. I've had a rough time getting photos to upload onto photobucket from my computer, but I think I finally figured it out. As I get more comfortable with it I'm sure there will be plenty of more posts asking for advice. So after sitting in the drivers seat working on the radio and trying to figure out why there are two hazard switches (neither of which work) on the dash, one beside the lighter and the other in between the brake and seatbelt lights, I noticed a long shard of rusty metal poking up through the seat, about the diameter of a wire clothes hanger, missing stabbing me in the leg by a hair. I pulled about five inches of it out and then pulled the seat covering off of the foam to see if there was more. Of course there was, and after searching this site, I learned that it was the wire support inside the foam. I used needle nose pliers to pull out all that I could. Of course this rust wasn't alone. The seat pan is almost unsalvageable. Then I started pulling up the carpet.
There it was. It didn't look too bad. only a spot or two behind the seat that had broken through the hard tar like heat/insulation stuff stuck to the floor.....then I started to scrape this tar stuff away. (ended up using an air hammer/chisel to get most of it. So now both seats are out, removed the carpet and insulation, (insulation in front passenger floor was soaked with some oily substance) removed the center console and back seat too. (Why did I start this just as the weather was getting perfect for cruising these beautiful, southern Md. country back roads? ) Used a wire wheel On my right angle grinder and got most of the rust off. That's as far as I've gotten so far. Will patch the small rust holes with fiberglass, Por 15 and insulation, sound / heat shield, carpet, etc. as soon as my wallet permits. In the mean time , I found this plate under the insulation around the gear shift. Can someone please tell me what the rubber grommet was intended to be used for?
Thanks in advance for the help, Matt
