What are the best simple mods for HP boost?
MIGHTY 8
Your car is a: 1980 Spider
Re: What are the best simple mods for HP boost?
Post by MIGHTY 8 »
MrJD wrote:Mark, have you ever weighed a factory drive shaft assembly?
Are you referring to the weight of the drive shaft itself?
Have always wondered if it's worth the trouble for someone (MM) to fabricate "lightened" versions
FiatMac
Post by FiatMac »
So Cal Mark wrote:au contraire, my 500 picked up 9hp upon installing the lightweight flywheel. Dyno comparisons were done before and after the swap
Actually, a lightweight flywheel will not add horsepower--it only frees up horsepower while you are accelerating(less horsepower is needed to accelerate the flywheel and is therefore seen at the wheel). Mark, I am guessing that the dyno you used was an inertial dyno which is always accelerating. If this had been on a load bearing dyno where the load is held at each speed (no acceleration at each point), no horsepower gain would be there.
However, that horsepower that is freed up during acceleration is a real performance gain as it allows for faster acceleration.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
parasitic loss.
bradartigue
Post by bradartigue »
Things that will absolutely increase performance that you can do without pulling out the motor:
- Buy a Weber 34ADF Carburetor
- Use a Marelli electronic ignition or one of the aftermarket electronic types. Use the Marelli only if your carb has a vacuum fitting for it, or if you are brave enough to drill one yourself (not hard).
- Get rid of the catalytic converter. If you feel bad about this then know that your car can pass emissions without it, FIATs actually burn pretty clean when properly tuned
Increase performance by just pulling out the head and refitting it:
- Simply replacing the old valves, having the head cleaned and surfaced, and installing new valve seals, gaskets, etc.
- Mild performance cams
- Hotter cams and adjustable flywheels
- Larger valves
- Polishing of the chambers and ports
And then we can go on and on and on. You have some guys here with $8k engines and they love them, and some guys with $2k engines and they love them. Start with simple stuff, the carburetor is easy to replace, so is the ignition.
