Blower fan 1977 cs1
- Your car is a: 1977 124 SPIDER 1800
Blower fan 1977 cs1
Only the fast speed works on my heater blower fan, the switch is new and the wiring seems sound, could the fault be with the fan motor unit? I have not removed the motor for inspection yet but does anyone know if the motors are often at fault?
Re: Blower fan 1977 cs1
if the motor runs on high, it's okay. Look at either the switch or resistor
ah thank you, I assume the resistor sits on the back of the motor?
always check the easiest thing first.
the switch is right there, out in the open. pry it out of the console and by-pass the switch from the hot wire to one, then the other wire. you most likely will get high and low fan speeds.......replace the $6.50 switch.
much easier than tearing out the fan motor and locating a resistor.
i bet lunch it is either the switch or the wiring and not the motor or resister.
Ok ...... guess what.........it's a faulty switch !
Mike, does your hat have the expandable band? Or will you have to buy a new one in a larger size?
Nice call.
Ron
Nice call.
Ron
pre-computer cars are fairly easy to diagnose electrical issues. add a computer and i walk away, shaking my head.
ALWAYS suspect a faulty ground, and ALWAYS try the easiest things first. if it was designed to move (switch) it has prolly failed after 30 some years of rocking back and forth.
those blower switches are so cheap, 30 minute life is more likely than 30 yrs
