Excessive heat on the passenger side
70spider
Your car is a: 1970 Fiat spider
Re: Excessive heat on the passenger side
Post by 70spider »
Great idea on replacing the stock screws with allen head bolts 8) . Getting to the bolts is the problem my seats do not move all the way back or forward so I can not access them with a normal screwdriver, even after cleaning and lubing them with lithium greese. I will definitly replace them with the allens.
Thanks, Pesto
2002 Mazda Protege5
2013 Buddy 170i
azruss
Post by azruss »
I used allens and they were too fat. I had to sand down the OD a bit to get them to seat.
4uall
Post by 4uall »
you may have to give the lube/oil/grease some time to penetrate then re-apply :wink: dont be afraid to put a little force when trying to move the seats back & forth 8)
had zero issues using these bolts :?
4uall wrote:I actually picked up 8 8mm hex bolts and used the allen key without even moving the seats to install them :mrgreen: pics tomorrow
