Stainless Steel Headers
Re: Stainless Steel Headers
be sure to dyno test your engine in it's current state, then dyno test with your new header to confirm that your theories are correct. Then make improvements where the power curve is deficient and dyno test again
Care to chime in at all Mark? Your headers would be the ones I buy if I didn't really wanna fabricate something myself for my car. I don't have many theories man, just assumptions... Which kinda worries me a bit. Can you tell me things that are really important? I will pay for the dyno testing and post results if you can help me along here. I don't even know what "stepper manifold" means or what it does.
Help! Lol
Also, is this gentleman right about not having the tubes at a 90degree angle off the flange?
Help! Lol
my thought is why reinvent the wheel. you have 3 sources for header design from proven sources, Allison, Croft, Abarth. Learn from the Japanese. Just copy what you see.
I don't have the blue prints, do you? Haha. I COULD buy marks here and copy it... Say mark, what's your return policy?azruss wrote:my thought is why reinvent the wheel. you have 3 sources for header design from proven sources, Allison, Croft, Abarth. Learn from the Japanese. Just copy what you see.
If you do, you've already got a restriction at the mounting face. The headers on my car continue out in line with the ports, before curving down.Jerosmith wrote:Also, is this gentleman right about not having the tubes at a 90degree angle off the flange?
Mick.
"before curving down" are you saying that having it 90 degrees IS the direction of the ports? This was my question earlier if the ports are indeed on a different angle than 90. And are we talking about the exact same engine? I see your name is 131...131 wrote:If you do, you've already got a restriction at the mounting face. The headers on my car continue out in line with the ports, before curving down.Jerosmith wrote:Also, is this gentleman right about not having the tubes at a 90degree angle off the flange?
Same engine. It's not 90, probably closer to 45, still not ideal to have the pipes perpendicular to the mounting face. I drive a 131.Jerosmith wrote:And are we talking about the exact same engine? I see your name is 131...
Mick.
Do you have a pic of your headers on your car? Can I get a better look at this angle?131 wrote:Same engine. It's not 90, probably closer to 45, still not ideal to have the pipes perpendicular to the mounting face. I drive a 131.Jerosmith wrote:And are we talking about the exact same engine? I see your name is 131...
http://www.fiatspider.com/f08/viewtopic ... ader+build
Have a look at the custom made headers. Some nice work.
Chris
Chris
- Your car is a: 1970 128
http://fiatspider.com/f08/viewtopic.php ... ss+headers
Here is my write up on stainless headers. looks like Guy has me beat
. Still, not bad for my first crack at it.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- engineerted
Yes, as Steve pointed out. The Primaries should come off the cylinder head in a straight line parallel to the ground and about 4 inches before any turns occur.
Ted
- Your car is a: Fiat 124 spider 1976
fiatfactory wrote:And if you want to get really pedantic... you should attempt to create an 'anti reversion step' where the pipe/header flange mates to the port... the 'top' of the port should be a flush fit level with the port roof, but quite a bit of benefit can be had by creating a step at the port floor (the slow side of the port) to prevent reversion of the exhaust gas back into the cylinder...
SteveC
![Wink :wink:](./images/smilies/icon_wink.gif)
"Nothing is more discouraging than unappreciated sarcasm." anonymous
