I assume I have one of three options (assuming I don't want to source a new cam tower and go through the hassle of changing it out: I don't
1) helicoil but probably hard to find M6 1.0 helicoils and there isn't much metal to work with there. Sureas hell don't want to crack or break that rib.
2) JB weld. Will this work in an oil environment?
3) Try to find a 25 mm long stud that is M6 1.0 on one side and something just slightly larger on the other, carefull retap cam tower hole making sure to catch any shavings, etc.
Anyone done this fix? How?
