So, I completed changing out my brake servo and master cylinder. Bit of a PITA getting the servo out. Lining up the valve control rod to get the pin through the pedal was a b atch! So here's may question (slightly embarrassing). After completing all the above, I noticed the foam rubber seal that goes between the firewall and mounting plate was under my desk!
