oil pressure instrument
- Your car is a: Spider 124 1800 coupe 1976
Where should the oil pressure level indicator be on the dial ?
- 124JOE
Re: oil pressure instrument
50 to 71 psi when hot,I have been told
- joelittel
I recently heard that it will be lower than that at idle speeds. 50-70 would be higher rpms.
Mine shows 60 psi 'at speed', and 30 psi at idle.
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
most of the gauges on the older cars read low. (sending unit orifice clogged). mine reads near zero when the car is warm and at idle.
Not zero at idle and hot is good. Should be 40 to 70 running down the road. The gauges, like all the others, are notoriously inaccurate. More just ballpark meters. Also, there is a red light off a separate sensor for zero. If that light doesn't come on or flicker you are probably good.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
My oil & volt gauges are both new VDO brand. I first thought that the oil pressure seemed high and so checked it with a manual (direct tube) gauge to find that the readings were the same.
Dave
Dave
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
