Orientation of 2-Way Valve?
I could swear that when I took this off, the flange on this 2-way valve (circled in the pic, #4) was oriented back towards the tank, so the body of the valve faces the front of the car, but now I am putting it all back together with new lines and the diagram seems to show the flange oriented towards the front. And I am damned if I can remember, should have taken pictures :roll: Anybody quickly verify which way this is supposed to face, flange back towards the tank or towards the front of the car?
Thanks!
Pete
Re: Orientation of 2-Way Valve?
Post by AriK »
The flange is oriented back toward the tank. There is an old post here that mistakenly shows it backward.
Personally I don't see what the big deal is, blowing through both ends of a new one has the same resistance.
Thanks! Mine was partially blocked with a bunch of grey pasty gunk. I cleaned it with solvent and WD40 and flushed it out and it only flows easily in one direction, so I think I either need to clean it again or get a new one!
Pete
