Pushing Later Style Bumpers Closer to Body
Nitrate
Your car is a: 1981 Fiat 2000
Post by Nitrate »
1981.2000. Is it possible, since the bumpers are on shocks, to somehow push the bumpers closer to the body? Can you remove the shock and slide it closer?
rjkoop
Re: Pushing Later Style Bumpers Closer to Body
Post by rjkoop »
Nitrate wrote:1981.2000. Is it possible, since the bumpers are on shocks, to somehow push the bumpers closer to the body? Can you remove the shock and slide it closer?
I did and love the look.
http://www.fiatspider.com/f15/viewtopic ... 30&t=32191
PhillySpider
Post by PhillySpider »
My rear bumper was pushed in. I wrapped a 250 lb climbing rope around it and my tractor to pop it out. I like the look better personally as pushed in there's alot going on with too much shadow hiding the lines of the car. 1,000 foot view perhaps they look better pushed in. To each their own, YMMV. IMO if you're willing to push them in and mitigate any safety they offer you may as well go bumperless. That's a huge visual improvement over the tube bumpers.
Frog2Spider
Post by Frog2Spider »
Yo Nitrate,
It's simple and looks great! Drill a 1/8 to 3/16 hole in the bumper shocks, letting the gas escape. Then, with some gentle force on both sides, push the bumper in so as to re-position it evenly close to the body. I left a small space so the rubber ends don't rub against the body. Once positioned, use the hole in the outer tube as a pilot hole to drill the inter tube again. Then run a screw to secure the fit.
Dave.
Frog2Spider
'81 - 2000 Spider
Nitrate
Post by Nitrate »
Dave, Thanks for detailing the whole procedure. Appreciate that. RB
weengra
Your car is a: 82 Spider 2000 + 76 128 Sedan
Post by weengra »
IIRC, they are oil filled, not gas. So, use a catch basin. YMWV.
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
Frog2Spider
Maybe the 'gas' was only O2, but I suspect it was heavier. It sprayed oil for at least 10-15 seconds, before finally just dripping. Wear safety glasses!
Dave
Frog2Spider
'81 - 2000 Spider
Let's see how fast we can shut down this poser.
