Will a steering wheel from a '75 fit an '80? The '75 has only 3 screws holding it on and my '80 has 6. Will this be a problem both in fitting and safety?
Thanks for all your wisdom in this matter.
shmoky
PS posted this elsewhere but not much action there... so dbl posted it here.
will this fit?
- Your car is a: 1980 Spider 2000 Pininfarina
will this fit?
Chetwynd, B.C. Canada
1980 Pininfarina Spider 2000
Sold: 1968 Corvette Coupe BB to buy the Spider
Re: will this fit?
I remember answering this elsewhere already...
Yes, it will fit. you need to remove the 24mm nut in the center to sway them.
Re: will this fit?
Thank you,
shmoky
shmoky
Re: will this fit?
What does it mean "to sway them"?vandor wrote:I remember answering this elsewhere already...
shmoky
- riverdadd
- Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: will this fit?
Prolly a typo. He meant swap I think
Re: will this fit?
LOL. Thanks riverdadd. I must have been half asleep.
shmoky
shmoky
- stuartrubin
Re: will this fit?
"Sway" as in "persuade!" I've had to take some extreme measures to persuade parts to fit, too!Yes, it will fit. you need to remove the 24mm nut in the center to sway them.
Stuart
1975 FIAT 124 Spider
Il Mostro di Frankenstein
- Your car is a: 1981 Fiat 2000
Re: will this fit?
Is the 75' steering wheel the factory thin imitation wood style? I would like to do this on my 81'as well. Is there an issue with fitting the plastic cowling around the steering column once the 75' wheel installed? I believe I read that there was some issue with the turn signal cancelling mechanism, something about a pin not being there? Does the horn wiring need to be modified? Are there some years of the factory imitation wood steering wheels that are better suited for this swap than others? I went thru all 35 pages of the archives on this subject and found that there are pieces here and there with some conflicting information. Can someone help me out with these questions and give me a heads up if I'm missing some thing? Thanks, RB
Re: will this fit?
They can sometimes be difficult to loosen after all those years. A wheel puller works best, but lacking one, you and an assistant can get it off. You sit in the driver's seat with hands on the wheel at 3 and 9 o'clock. The assistant places the small end of a ball peen hammer on the end of the shaft. He strikes that hammer face with another hammer. At the same instant, you jerk the wheel towards you. Keeping a few threads of the 24mm nut still on the shaft will prevent you from hitting yourself in the face with the hammer(s) and/or the steering wheel.
Re: will this fit?
Yes, I meant swap
I never needed a steering wheel puller on a Fiat. Just whack the steering wheel hard on one side once the nut is off and usually it breaks loose. On some other cars I've seen some extreme difficulty to remove wheels, but not on a Fiat.
- aevansgatech
Re: will this fit?
I tried to take mine out the other day and was surprised it doesn't slide off easily with the 24mm nut out of the way. Good to know it's not uncommon and I can give it a whack to loosen it up
1979 Spider 2000 (gone)
