Got my floor LED Floor lighting in finally. It's mounted to the support brace underneath the full length.
Cheers!
Rob
LED Floor Lighting
- v6spider
LED Floor Lighting
http://www.v6spider.com
Re: LED Floor Lighting
I like that! Much better than the door switch operating the dash courtesy light, which doesn't supply even remotely enough light. Plus there is nothing visible, so it maintains the look of stock (Until they peek under the hood of course..... )
- Your car is a: 1977 Fiat 124
very nice - how did you wire it ? is it to the door switch or a manual switch ?
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
1988 Fiero GT
- v6spider
Thanks guys! Yeah I think it turned out better than I expected.
Cheers!
Rob
Jagonza: I have it wired to the door switches and I also have a switch on the dash to operate it as well.jagonza wrote:very nice - how did you wire it ? is it to the door switch or a manual switch ?
Cheers!
Rob
- Sparky
- Your car is a: 1978 Fiat 124
Are those the multi-color leds that come on a reel? I've used that for lighting on some of the machines I've built. Great idea, just make sure you don't let the passenger set it to the fast-random setting while you're driving
-= 1978 Fiat Spider =-
- v6spider
Nope, just green led strips but yeah that would get confusing for sure.Sparky wrote:Are those the multi-color leds that come on a reel? I've used that for lighting on some of the machines I've built. Great idea, just make sure you don't let the passenger set it to the fast-random setting while you're driving
Rob
I was thinking of doing the same thing. I always have problems finding ignition key place when dark outside.
Where did you get strip? How long was it? Voltage?
One suggestion that might make it work well for that function is to add a circuit relay delays. eBay has tons of them. Wiring is easy. This way, when door opened, light goes on; you can close door ; but light stays on for a user defined period (for instance 10 sec). Still, in parallel , keep the on-demand light switch
Below is a link to one of these devices:
There are hundreds of them on eBay as low as $3.00
http://www.ebay.com/ulk/itm/272534984232
Actually, I just thought of two other uses: get two more. One for the door switch; but have it time out after 5 minutes , so you don't drain battery if working on car or accidentally left door open; and for trunk light
- Sparky
I've used these weatherproof 12V kits off ebay on various machinery.
eg. https://www.amazon.com/WenTop-Waterproo ... B00X7JUN0I
You just cut the strips to length. You don't need the power supply when wiring up in your car and if you only want a single color, you can buy even cheaper kits.
eg. https://www.amazon.com/YITAMOTOR-Motorc ... 018SBDF5O/
They don't draw much power, there's no need for fancy switches or relays, just a 2-5A fuse. Run battery power to the + side and run the ground to your door switches & a manual switch to ground if you want them to work whenever you open a door or turn them on.
- v6spider
I used 24" sections and they covered the full length perfectly. You'd have to build up a pcb circuit for a delayed turn off but it can be done.. otherwise everything sparky mentioned applies.micbrody wrote:I was thinking of doing the same thing. I always have problems finding ignition key place when dark outside.
Cheers!
Rob
Do you purchase them in 24" sections? Or do they come in long roll and you cut to size? Brand?
Reading some reviews on Amazon, some brands seem to have some issues (not bright, not all leds working).
As for the delay circuit, the eBay link has installation video. Don't need PCB, just connecting loose wires to the unit. Looks crazy easy.......of course I have regretted say that for many of my projects !(installing ceiling fans.......)
- v6spider
Nope, bought them precut with wires attached. Waterproof sections.micbrody wrote:Do you purchase them in 24" sections? Or do they come in long roll and you cut to size? Brand?
Cheers!
Rob
