The details are we built a performance 2L for this 1973 Spider and converted it to FI using the oem Bosch L-Jet system. The motor received 10:1 forged pistons, ported cylinder head with oversize valves, 284 street cams, lightweight flywheel, lightweight crank pulley, adjustable cam gears, mls head gasket, head stud kit, Computronix ignition and of course the new electric water pump.
The electric water pump solves several common issues by first eliminating the thermostat and making bleeding the system a breeze.
Engines with thermostats don't warm up evenly, there are hot spots due to lack of circulation as the engine reaches operating temperature. The electric kit starts circulating water at a slow rate as soon as the key is turned on (this is why bleeding is so easy). As the engine approaches the target temperature that you've chosen the pump ramps up the circulation speed. If the engine temperature rises above the target temperature, the cooling fan is turned on. If the temp rises 20 degrees above target, you get an audible warning. When the engine is turned off, the pump circulates water at a slow rate for up to 3 minutes to prevent heat soak.
During engine break-in, we had the car running at 2500 for 20 minutes in the shop on a 95 degree day. Engine temp stayed in the 180 range.
Without needing to waste hp turning a water pump pulley, this engine is REALLY responsive. On this current application we cut the impeller from the rear of the mechanical pump to allow full flow from the electric pump. At some point we'll have a block off plate available so there won't be any need to use the mechanical pump.
We're finalizing all the various pieces to include in the kit, but these will be available soon! Here are some pics of the system;
![Image](http://i.imgur.com/uxM4QNl.jpg)
This is the controller. As you can see I've got it set at 160 as a target temp, the solid lines show the current temperature and the fan symbol in the lower left lets you know when the fan is on. Very easy to set so that if you want higher temps in cold weather or cooler temps in the summer, it only takes a second to change the setting.
![Image](http://i.imgur.com/R4V8El2.jpg)
the pump gets plumbed where the thermostat used to sit; lower radiator hose to the inlet, outlet into the engine and heater return into the pump. Pretty simple
![Image](http://i.imgur.com/I87tdev.jpg)
quite a bit more room around the front of the engine without a water pump pulley and a belt from the crank to the alternator
