Brakes good -- squeaky wheels around turns
Fiatcatapult
Post by Fiatcatapult »
Brakes good, new calipers, and new pads -- what causes squeaky wheels around turns and when slowing down.
Not sure if it's coming from the front or the rear.
like something is out of round squeak.
klweimer
Re: Brakes good -- squeaky wheels around turns
Post by klweimer »
Dragging e-brake? Loose front bearings?
Fiatcatapult
thanks ... i'll check for both.
Is there any pulsating in the brake pedal?
Fiatcatapult
No almost none to minimal....
TStark
Your car is a: 1975 Spider
Post by TStark »
Some things to consider...
Front Bearing freeplay excessive?
Are your sliders lubricated or installed dry?
Are the leading edges of the pads beveled? if not, do so with a file.
Anti-squeal pad on the backing plate?
If not, there are some permatex products to spray on the backing plate, let dry to tacky, then install.
Fiatcatapult
I will be checking all that you mentioned in your post.
Thank you
DieselSpider
Post by DieselSpider »
Steel rotor squeaking or tire squeal? Could be alignment issues or worn front suspension if its tire noise. If its brakes look at loose/worn front wheel bearings. It would be rare for rear wheel bearings to have that much effect but it would not hurt to check.
Here is a great video on how to properly pack a front wheel bearing. Many times front wheel bearings fail because they were not packed correctly as show here by Dan Anderson of the American Farm Journal:
https://www.youtube.com/watch?v=BhL1uAp_WCw
