79 spider
79 spider
I need to know where the brake fluid reserve,washer pump and the washer over flow goes. I have not worked on the car for two years.I sent he head off to be redone.I KNOW But he builds engines for teams in NASCAR. I know he is slow. also where does the coil go
Re: 79 spider
The brake fluid resevoir sits on top of your maste cylinder, rear part of the engine bay, drivers side. The coolant overflow bottle is on the oposite side of the fire wall from it (passenger side.) The washer overflow is usually down the outside of the fender.(Just kidding, I know you meant washer fluid resevoir). The newer cars have a plastic bottle in the left front corner of the engine bay, older cars had a bag on the inside fender on the passenger side. I don't know which they had on a '79.
Ron
Ron
Re: 79 spider
I keep my pics here http://flickr.com/ If you thumb thru, youll probably find anythin but the washer thingie
![Wink :wink:](./images/smilies/icon_wink.gif)
![Razz :P](./images/smilies/icon_razz.gif)
Re: 79 spider
78-79 and carbureted '80 window washer bag hangs in the right hand front corner on the inner fender well. there should be two metal tabs perforated out of the sheet metal to hang the two metal grommet reinforced holes for the bag.
