Springs and shocks 1980 Spider without bumpers
greenspider
Your car is a: 1980 Spider 2000 FI manual
Post by greenspider »
I've read a zillion posts on this topic, sorry for another. What springs and shocks would anyone suggest for my 1980 Spider? I removed the stock bumpers and don't intend to re-install them. I'd like the car to sit right but have a comfortable touring ride. I run a sump guard and it already seems really low at 5 inches clearance. I currently have stock 13 inch wheels and springs with KYBs. I handles great in the twisties, but rides like a dump truck over bumps. What's the best ride height and measured from where? I also have a set of 14 inch turbo wheels that I plan to install but with lower profile tires shouldn't change the height. I also have a hardtop which increases weight. All that said, I'm looking for a better ride while retaining handling. Thanks for any recommendations. Tony
redcars
Re: Springs and shocks 1980 Spider without bumpers
Post by redcars »
The turbo wheels with 195r60 are just a little shorter than OEM size 13's. I have them both. Putting on koni in place of the KYB's will lower your ride hight a little. I have AR's performance lowering springs on my 82 with Koni reds, which are no longer available. I've driven 400 miles a day with it. I like the rider, but it is stiffer than stock. My 81 has OEM springs with KYB shocks and 13" wheels with 185/70 tires. The KYB's are OK if the road is smooth. The ride hight on the 82 is low, you just need to pay attention to where you go.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
geospider
Post by geospider »
I have the AR progressive springs with Koni yellows. Love it, about an inch lower. The Koni's have a softer feel than the KYBs which for these cars, I believe dampen the proper way. The springs work harder, the harder you drive on them. Also with 15" and 205/55 tires, so they offer a bit sharper ride. Most roads are fine.. watch the bumps. I think the same set up with your 14" and proper tires, you will be fine.
Geo
greenspider
The AR site notes 24 inches ride height at the fender lip with their springs. Is that the preferred height? I assume that’s the same as Euro. Any preference between AR and Vogtland? Tony
chrisg
Your car is a: 1971 FIAT
Post by chrisg »
First & foremost, I would say get Konis. Yellows on the softer end of the spectrum with the AR springs is a very nice recipe. (Most) Gas shocks will do the 124 suspension no favors. You could have a play with springs...known early springs may be nice (there is a paint stripe, I believe, to identify them, but good luck finding them, who knows if an early car today has its original springs, etc) & I cutting stock springs can also work. In the great scheme of things, the “modern” progressive springs on the market are pretty affordable, so other approaches (of which I have vast experience having done all this at a time before there were as many good options & when I had a much smaller budget) may not be worth it.
For the wheels/tires, just do the math. There are plenty of options . At one point I had a 124 Coupe with 215/60 tires on 14” Biturbo wheels, Konis and IAP (remember them?) springs with the upper plastic cap removed from the rear to level the car out. I am sure I would have been told that this would have never worked, my speedometer would be off, and whatever else. 99% of this is will be easily reversible if you change your mind.
Chris Granju
Knoxville, TN
