E brake
2000spider
Your car is a: 1981 2000
E brake
Post by 2000spider »
I've got a question maybe someone can help me with. I've got an 1981 2000 When I tighten the e brake tight enough to keep car from rolling, I have the smell of brake burning when I drive. If I loosen it just a little I will roll on the smallest hill. What am I missing? thanks
rridge
Re: E brake
Post by rridge »
The parking brake self-adjusts to provide the proper distance of pads to disc if the caliper has been properly reset when the pads were installed and the pads are the proper thickness. You do not set the pad to disc clearance once they are installed. Yes, the brakes will drag if you try to correct mis-installed pads with the parking brake cable adjustment. The cable must have some free play when the handbrake is released.
Even when the rear brakes are properly installed and adjusted it may take hundreds of miles before new pads are broken-in and grabbing sufficiently hold reliably on any kind of grade. If the pads have been dragged and overheated they may never grab.
The 124 was one of the first mast produced cars to use rear disc brakes. The mechanism is unique and unfamiliar to most mechanics. However, there are many threads on this site that address their service once you master the search function. The proper installation is spelled out in both the factory service manual and aftermarket manuals such as Brooklands.
2000spider
Re: E brake
Thanks for such a quick response They are new, I'm pretty sure they are installed correctly, so I'll give them some time. They probably only have about 50 miles on them have a great day
Re: E brake
One other thing to check is to make sure that the metal wedges that hold the calipers in the mounting bracket on the axle are properly lubricated. You can buy a special grease for this (Google "caliper grease" or the like), and I suppose a thin coat of ordinary bearing grease might work well enough. Remove these wedges, smear with the grease, and reinstall.
The brake calipers sort of "float" on these wedges, and if they are corroded or totally without grease, the pads can continue to push against the rotor even when the brakes are released.
DieselSpider
Re: E brake
Post by DieselSpider »
18Fiatsandcounting wrote:One other thing to check is to make sure that the metal wedges that hold the calipers in the mounting bracket on the axle are properly lubricated. You can buy a special grease for this (Google "caliper grease" or the like), and I suppose a thin coat of ordinary bearing grease might work well enough. Remove these wedges, smear with the grease, and reinstall.
You really need the higher temperature caliper grease and it should be renewed at least every 2 years so I do it at the same time as the regular 2 year brake fluid and coolant flushes.
2000spider
Re: E brake
thanks I'm heading out now to check everything
