DIY Bumper Delete Lights
joshuagore
Post by joshuagore »
In an effort to get some sort of turn signals I headed to my local NAPA. I was helped by a car nut to find something that would go in the Ralph Nader bumper holes.
I found a solution which requires the drilling of 2 pilot holes for screws or not if you are crafty with some washers.
Here is the picture, and I will keep everyone in suspense until tomorrow when I am back at the shop where the boxes with part numbers await.
There are 2 bezel options. I chose the one without the 'eyebrow' detail, but I might go back and get the other one. I am also considering painting the bezel black.
Josh
fiatS2000
Re: DIY Bumper Delete Lights
Post by fiatS2000 »
Can you post a close up side view picture.
Do the lights point forward or down at the road?
joshuagore
fiatS2000 wrote:Can you post a close up side view picture.
You can angle them before you tighten down the compression style grommet... I think.
Yes I can take a pic.
Josh
Danno
Post by Danno »
c'mon with the details already!!!! part numbers, price, more pictures!!!!!!
joshuagore
ooops. Sorry anniversary week. Tomorrow real life starts again.
Josh
KRegester
Post by KRegester »
Tease!
We need details....
this is the kit I sell
joshuagore
So Cal Mark wrote:this is the kit I sell
Mark,
Your kit is better than my setup, but it also costs more ;)
I swear tonight I will be tinkering in the garage and will snap pictures..... I PROMISE!!!!
Josh
Danno
Post by Danno »
Josh, I swear I read the words "I promise". where are those pictures already?
TulsaSpider
Post by TulsaSpider »
yea what he said....
narfire
Post by narfire »
Hi there. I deleted the tube bumpers as well. I went to a honda motorcycle shop and found a couple of rear turn signals for a bike.They come out at right angles. I think they were about $20 cdn total. I made a spacer for the end to screw into ( a machine shop can do this) or I was told a spacer for electrical trays might work. and then drilled a hole into the support bracket for the front tube. A washer,and nylock nut held it together. the lights are in the air hole to the outside and the tube holes have the rubber bumperettes.I'll try a photo[img]http://i708.photobucket.com/albums/ww88 ... iatlt2.jpg[http://i708.photobucket.com/albums/ww88 ... t1.jpg/img]Haven't figured out how to get the picture up yet but they are in all these letters if someone can pull them out great thank you.
Good luck
Narfire
mdrburchette
Post by mdrburchette »
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
ga.spyder
Post by ga.spyder »
I cant seem to get the pics to zoom for a better look,but the fit looks great.Do you have a part number,or model of the bike they came off? Those lights,and some SoCalMark bumperettes,and I could be on my way to bumper delete.Yeah!!
Craig
Craig Nelson
Fling It Around Turns !
narfire
Post by narfire »
Good morning. The lights actually came from a box of lights they had, all in individual plastic bags. Penticton Honda is the place I used but I'd guess most honda stores that sell bikes and quads would have them. I think they would be off an enduro type bike. Too bad I did not get a shot of the spacer,needed about an extra 3/4 - 1 inch and used a right angle drill to get at the supports.
Good luck
Chris
PS can you see the bumpers are held in place with springs. One each side of the metal "rod" seems to work well, no movement,used a string to pull them back and ran the bolt through the ends. the rears are different. Need to fabricate something different there.
kuhndg
Post by kuhndg »
Denise,
Where did you find your bumperettes? How much? I have seen a couple versions on Ebay, but the set I like will cost $400 by the time it gets to my door.
