![Question :?:](./images/smilies/icon_question.gif)
How to use compensator bypass hose?
- TulsaSpider
Ok I got my wee lil hose from Mark. I jacked up and supported the car. Found the compensator. It has a hard line coming in and a hard line coming out right? What next? I couldn't figure out what to do? Do I disconnect the two hard lines and bend them down? Then what? The compensator hose has 1 male fitting and one female fitting??? So that doesn't sound right? So I am I the only one who couldn't figure it out?? ![Question :?:](./images/smilies/icon_question.gif)
Re: How to use compensator bypass hose?
the bypass hose should have two female fittings, It just bends in a 180 to link the two hard lines together
- TulsaSpider
Maaaaark I yam thinking maybe you senda me the wrong thing!
![Image](http://i46.photobucket.com/albums/f139/celticclark/Fiat/100_0476.jpg)
Yeah, that is not the correct hose. The bypass hose has 2 female ends. (Sounds sexy.)
Hi!
I wonder how this bypass hose work. Does it make any different when you brake?
Maybe a silly question
Regards
FMO
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Regards
FMO
- TulsaSpider
There are several threads just do a search for "compensator"
Mark maybe you should delete this post since it's resolved?
