Cold Air Intake
Re: Cold Air Intake
Well Done! I am still looking for a really good design for the FI cars. The ones proposed so far all seem to have significant drawbacks.
- Your car is a: Fiat 124 Spider 2000 Cs0
Re: Cold Air Intake
Hi there,
I started with drilling two holes as low and big as possible in the front part of the original plastic filter housing.
From there I will guide fresh air via two flexibles hoses into the air box without changing the original design...
I like the idea with the Thermo-Tec heat shield around the original rubber intake part... and it looks more dangerous too
Cheers
Norbert
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Cheers
Norbert
- phaetn
- Your car is a: 1974 Fiat Spider 1800
Re: Cold Air Intake
Heya, Wetminkey. I've just recently come back to the boards after an absence and see you PM'd me quite a while back (a year and a half ago) about head gaskets. I *think* I responded via e-mail but cannot be sure. Sorry for the oversight if I didn't.wetminkey wrote:I finally got mine setup - it was an easy adaptation of my old '79 Spider air cleaner and cold air intake to my 32/36 DFEV. Almost ridiculously easy,...!
Wish I had skipped the purchase of the usual, chrome "Meaner Cleaner",...
I have a 32/36 DFEV, too, but with a tall lunchbox air cleaner. Have you noticed much of a difference with your routed cold air intake? I could run a 4" dryer hose to get cold air to the area but won't be able to seal it off. Wondering if it's even worth the bother...
phaetn
Re: Cold Air Intake
Yes. The intake from in front of the radiator keeps your carb from sucking in hot air from under the hood, and the cool air (from the front of the car) provides horsepower to an engine at running temp. At speed, the intake provides some positive pressure,...
Greatest advantage of all, is that the filtration area is so much larger, and the replaceable filters are available from any local auto parts store.
I also like the ability to easily vent my crankcase and gas tank (via the charcoal filter) to the air cleaner housing. And the air cleaner housing sure makes the 1979 car look pretty original under the hood,...
I think that the ol' "S-shaped" 'snorkel' intake tubes, from the '79 and '80 carb versions, can still be found,...but there are many other ways to plumb a carb's air intake,...!
Best of luck with your car, whatever you decide. Have fun!
Cheers, Todd.
Cheers, Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Re: Cold Air Intake
"Thanks much Gus"
Do you happen to know how to get a hold of gus? I bought the kit but need another heat shield.
Jahmal
Jahmal
Re: Cold Air Intake
The shield is a good barrier for header heat. A couple other things I have seen or done. Seen - I have seen one custom snorkel where they took black plastic tubing and routed it from a hole in the air damn up to the cold air intake. Done - Drilled three holes with 2 1/8 inch bimetal whole saw bit in shape of triangle in the panel behind the grill but in front of the air intake to let cold air flow into the engine bay. The cooler intake temps on a warm engine do increase HP a bit.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
