70 fenders on a 77....Can it be done??
Akgriffith
Your car is a: 1977 and 1970 Spider
Post by Akgriffith »
I have a 1977 Spider virtually rust free. However it does have collision damage on the front right fender. I also have a 1970 Spider with a completely rusted out floor and inner rockers. Can I put the front fenders from the 70 on the 77? Will the holes for the bumper line up (I'd be using the 1970 bumper). Has anyone tried this? I prefer the look of the 70 front bumper and blinker, so this would be a good retro fit if it can be done.
Alex Griffith
1977 124 Spider - Slowly coming together
Odoyle
Re: 70 fenders on a 77....Can it be done??
Post by Odoyle »
1) Pretty sure a 70 front quarter fender will fit on a 77, but the bumper holes/ turn signals will be different.
2) If your going to go through the trouble of replacing one front fender, I would consider swapping the whole front clip from the 70 onto the 77. Though the bumper bracket location are placed on the inside of the lower front crossmember pre 74 so the holes may not line up with the 77 front end. That being said you could weld closed those holes and cut new ones. No quick solution to this one...
Akgriffith
Odoyle wrote:1) Pretty sure a 70 front quarter fender will fit on a 77, but the bumper holes/ turn signals will be different.
I never thought of using the whole front clip. I'll do some measuring and see if that would work.
Alex Griffith
vandor
Post by vandor »
I assume you know the fenders are welded on, not just bolted?
Akgriffith
Yeah they are welded on. As far as using the whole front clip, that would probably work but it's more than I feel comfortable taking on. I think I'll get the collision damage repaired and either go bumperless or get one of those bumper conversion kits.
Alex Griffith
carl
Post by carl »
I helped remove a spider front fender assembly once and let me tell you it was an amazing pain in the ass. Those things are welded on to the body in more places than you realize. Take a careful look at how they are attached before you decide to take this job on.
markwest124
Your car is a: 1978 Spider 124
Post by markwest124 »
I keep reading how difficult it is to remove/replace a fender. I find myself with no choice. Can someone please provide some details? Cheers, Mark
A Fiat spider is unibody construction, that is, there is no "frame" per se, and the body panels (welded together) are the frame. I would think any body shop could replace a fender, but it is likely way beyond what your average home mechanic could do. My '69 spider had it's front fenders (and hood) replaced when my dad crashed the car in a snow bank shortly after he purchased it new...
