Vacuum capsule on distributor question...
Re: Vacuum capsule on distributor question...
Its a three pronged fork that is bolted to the engine block and points forward. It is left of the crank pully and below the water pump. NO numbers!
Which manual did you get from IAP? I have the Brooklands and the Clymer, of these two the Clymer is a little better on this issue. It has a section that is specific to the 2.0 litre years.
Here's a picture of my timing tab, the bottom arrow it 10°, middle is 5°, and the top is TDC (0°) If your tab hasn't been removed, you have to look under/around the thermostat to see it.
Ron
Ron
Thanks Ron..... I see the part of the tab that has the circle. I might have to remove the timing cover to see the rest of the tab with the prongs. It looks like you have your cover removed in the picture.
no need to remove the cover, the tab is clearly visible
Nope. My cover is on, I just held the camera low into the engine bay. You should be able to see the whole thing by bending down and looking behind and below the thermostat.
Ron
Ron
Isee it! I see it!
Thank you for your help.... Just one more silly question, where do you hook up your positive lead from the timing light? Do I run an extension from trunk?
Also.......... Which prong is 10 degrees? The larger, top? middle or bottom?
I use the battery post on the starter for the 12V source. The bottom arrow is 10° BTDC. You'll find that the round hole lines up with this nicely, as this is where the notch in the pullley will show up.
Ron
Ron
I'd like to jump in with a question of my own. Having the same problem. Is my 79 2000 vacuum capsule just as replaceable as this one? I can't find anything for my year except the dizzy and vacuum capsule together.
Anyone know?
Anyone know?
I replaced mine a while back, and the new one blew the diaphragm out in about three months. I capped off the vacuum line and run without it now, and honestly, I can't tell the difference in performance.
Ron
Ron
sounds like your butt dyno needs calibration! Seriously, the vacuum advance works under light load/high vacuum situations so it affects fuel mileage more than performance. Expect about a 10% drop if mileage without the vacuum unit working. But then if you drive with a heavy foot it won't make much difference.
I ended up taking the dizzy out to change the Vacuum advance. Everything went back together without any problems.... (I had confidence, because I have removed and replaced quite a few dizzys in my time).... I set the timming to the lower smaller arrow pointer and then advanced it about a 1/8 inch beyond that (however many degrees 1/8" is?). Sounds and starts like a champ. I will take it for a test run today.... It was raining all day yesterday.
Thank you all for your advise which helped me get through this dilemma.......
Well, all right! Congratulations.
Ron
Ron
