The first set of pics are of the carb. Just want to know if anyone sees anything that looks amiss, or like it is missing anything. I know that I'm missing one of the threaded posts that hold the air cleaner on. Actually two holes are stripped, so only two posts are holding it on anyway. I looked over Brad Artigue's docs, and will do so in more detail in days to come, but wanted to get feedback from some of you who are familiar with what you are looking at.
These pics are where the pipe that comes out of the air cleaner is bolted down. Notice that it is only bolted on one side, and the threaded post is gone from the other side. Is this anything that I need to be concerned about?
This last pic is of the underside of the air cleaner. There are two hoses attached here, the larger one holds on pretty firmly, and the smaller one just slips on - not tightly at all. I was surprised it stayed on at all, but it must be sitting in a spot where there is nothing pressing it to move. Question is what are each of these hoses, and should they be attached with clamps, or should I just leave them as they are?
Thanks much!
-- se
