shim shuffling
shim shuffling
is it ok to shuffle around valve shims in order to even out clearances? Or once the shim wears to a certain lobe it should only be replaced with new?
- Curly
- Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Re: shim shuffling
Shuffle away
Any obviously worn shims should be thrown out.
Curly from Oz
124AC coupe http://gallery.italiancarclub.com/124og ... -AC-coupe/
124CS1 spider http://gallery.italiancarclub.com/124og/curly/album52/
