OK, it's me again and I still am not able to build any pressure in the brakes system
. But, I had a self proclaimed "Fiat Guy" come over to the house and take a look (he is a mechanic and bosts building many Spiders in the past)
. Anyway, his diagnosis, which I have a hard time believing
, is that the brake booster is bad. While, I am not in total disagreement with him on this, I don't quite believe his rationalle. He states that if the booster is bad then the knetic energy placed on the brake peddle will not get transferred to the MC
. Thus, the system will not build any pressure and the peddle will continually go to the floor with only the spring tention as resistance
. Personally, I believe that if this is fact, then any booster failure would result in total brake failure and I have a hard time believing that a car company would put something out there with such a possible catastrophic legal issue looming over the bottom line
. Anyway, what are your thoughts? It seems to me that a brake booster is there to assist in the actual pressure needed for braking and a bad booster would result in more leg pressure and difficult braking. Am I right or am I wrong? My booster has NO brake fluid leaking. Also, it seems to me that if I did have a leaking booster than it would be a result of a faulty MC as the booster does not have any fluid goint to it
. Anyway, let me know - Please
